2000 Honda Passport NO START
2000 HONDA PASSPORT
128,000 MILES • 6 CYL • 2WD • AUTOMATIC
DOTANHA
NEED TO KNOW WHY MY CAR CRANKS SLOW ,NO START... AND PLUG GETS WET AFTER FEW CRANK. WHAT WOULD BE POSSIBILITIES NEEDS TO BE CHECKED OTHER THAN FULL CHARGE BATTERY . THANKS
Jan 31, 2009 at 4:27 AM
KHLOW2008
  • 41,814 POSTS
Hi dotanha,
Thank you fo the donation.
When cranking speed is slow, the required compression might not be achieved so it will not fire up. After a rew cranks it will flood as excessive fuel is getting into the cylinders. this would sometimes cause the sparks plugs to foul up and might short them as well.
If a fully charged battery works, then there is nothing else that you need to check.
Jan 31, 2009 at 4:48 AM
DOTANHA
this car has been sitting for a long time it starts one time sounds great but few days after that . it cranks slow now ... could it be jumped out of timing?? am i going to be able to get this engine somehow???? or, should i buy new engine?? what do you recomend???
Jan 31, 2009 at 2:35 PM
KHLOW2008
  • 41,814 POSTS
If the battery is weak, it would not crank fast enough to start. I would suggest getting a jumper to try and start.
After sitting without starting over long period of time, if the battery is failing or there is a drain, the battery would not be strong enough to start. Engines do not go bad easily after sitting for some time.
Jan 31, 2009 at 5:06 PM
