2000 Honda Passport Long time to start but eventually start
111,000 MILES • 6 CYL • 2WD • AUTOMATIC
DATABIZ
The 2000 Honda passport takes on long time to start but eventually starts. Sometime when warn starts fine. The dealer tells me that it is the fuel pressure regulator. What do you think ?
Thank You
Dec 19, 2009 at 4:06 AM
KHLOW2008
  • 41,812 POSTS
Hi databiz,
It can be the fuel pressure regulator but this item seldom fails.
If starting is difficult after resting for a while and performance is reduced from previous, the more likely fault would be a pressure leak along the fuel lines. It could be intank of which there would be no tell tale signs. You would need to remove the fuel pump to check.
Dec 31, 2009 at 1:50 AM
