Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Honda
Passport
Engine Cooling
Water Pump
Replace/Remove
1999 Honda Passport water Pump Removal
1999 HONDA PASSPORT
80,000 MILES • 6 CYL • 2WD • AUTOMATIC
JONNYEMM
MEMBER
1 POST
My question is where exactly is the water pump and if i have to lift the engine to remove it Thankss!
Mar 13, 2010 at 4:14 AM
KHLOW2008
Experienced Mechanic
Hi jonnyemm,
The water pump is located behind the timing belt cover.
The engine need not be removed but you would need to remove the radiator and timing belt to get at it.
Mar 13, 2010 at 11:37 PM
Add image or video
Ask a new question
Engine won't start
Engine overheating
