1999 Honda Passport trouble codes P0171, P01714
1999 HONDA PASSPORT
108,000 MILES • 6 CYL • 4WD • AUTOMATIC
PAUL02724
I know trouble codes P0171, P01714 mean bank 1 & 2 too lean, but what does that mean I should do? when I start it up the rpm's drop real low then go back up, and sometimes goes too low and stalls. Any help would be greatly appreciated.
Jan 9, 2008 at 3:05 AM
MASTERTECHTIM
  • 4,750 POSTS
USUALLY WHEN BOTH BANKS ARE LEAN THERE IS A VACUUM LEAK.
Jan 9, 2008 at 3:58 AM
2CARPRO JACK
  • 11,533 POSTS
Or it could be the Mass Airflow Meter or a weak fuel pump
Jan 11, 2008 at 8:02 AM
MASTERTECHTIM
  • 4,750 POSTS
i totally forgot about the mass air flow sensor. this could definately cause this problem. remember these are our opinions not facts. thanks for pointing out the mass air flow jack.
Jan 11, 2008 at 8:12 AM
2CARPRO JACK
  • 11,533 POSTS
n/p bro....takes a village
Jan 11, 2008 at 9:44 AM
PAUL02724
[quote:0203f44f9b="mastertechtim"]USUALLY WHEN BOTH BANKS ARE LEAN THERE IS A VACUUM LEAK.[/quote:0203f44f9b]
Just wanted to Thank You. You were right about my problem. I first had the mechanic change one of the 02 sensors, and that didn't work then he sprayed some stuff around the intake and realized that was where the problem was. It had a cracked intake gasket, which is made out of plastic. Problem is fixed. I told everyone how you were right and that I would be using you again.. Thanks Again, and have a Great Day.
Jan 14, 2008 at 2:04 AM
PAUL02724
[quote:c20a25ea3a="2CarPro Jack"]Or it could be the Mass Airflow Meter or a weak fuel pump[/quote:c20a25ea3a]
I first had the mechanic change one of the 02 sensors, and that didn't work then he sprayed some stuff around the intake and realized that was where the problem was. It had a cracked intake gasket, which is made out of plastic. Problem is fixed.. Thanks Again, and have a Great Day.
Jan 14, 2008 at 2:06 AM
