1999 honda passport the speedometer stops working when the service brake is applied what could cause this
Aug 22, 2010 at 1:38 PM
KHLOW2008
✓Experienced Mechanic
Hi alan evans,
The VSS is not related to the brakes so the most likely cause would be loose wire connectors. When brakes are applied, some movement is causing wire connections to be tugged at resulting in no continuity.
