1999 Honda Passport My truck won't start!
197,000 MILES • 6 CYL • 4WD • AUTOMATIC
RACQUEI TURNER
When I turn the ignition on, it sounds like it wants to start, but the "kick" that turns the engine on does not take place. What do you think the problem is?
Aug 29, 2008 at 10:45 AM
BMRFIXIT
  • 19,053 POSTS
I would start with fuses and the battery
check fuses
check battery terminals (clean and tighten )
check and make sure battery full and in good health!!
check the starter
locate the starter check terminals make sure they clean and tight
check for power on the big terminal all the time
S small terminal has power when u turn the ignition switch to start
and if so starter no good
Aug 29, 2008 at 11:06 PM
