1999 Honda Passport how to fix trouble codes P0171 -P0171 -
1999 HONDA PASSPORT
LA GANZA
  • 44 POSTS
Engine Mechanical problem
1999 Honda Passport 6 cyl Four Wheel Drive Automatic
I get trouble codes P0171 P0174 P0304 how can i fix it. i'll appreciate you help thank you
Mar 29, 2009 at 5:57 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Codes P0171 and P0174 indicate Bank 1 and Bank 2 are running lean. Suspect faulty oxygen sensors located underneath vehicle on exhaust system. Also inspect MAF (Mass Airflow) sensor.
Code P0304 indicate a cylinder 4 misfire detection. Need to inspect your spark plugs to ensure all cylinders are getting proper spark.
Post results and I will follow up.
Thanks for using 2CarPros.com!
Mar 29, 2009 at 6:06 PM
LA GANZA
  • 44 POSTS
HI i HAVE 99 HONDA PASSPORT AND i GET TROUBLE CODE P0304 i KNOW THAT THIS MEAN CILYNDER MISFIRE DETECTED i CHANGE THE SPARK PLUGS , COIL AND STILL GETTING THIS CODE ANY IDEAS? COULD BE THE FUEL INJECTOR SOUND LIKE IS WORKING SO I REAL CONFUSE. THANKS FOR YOU HELP
Apr 9, 2009 at 12:21 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Does that cylinder get good healthy spark to the plug? Check fuel pressure at the rail as well.
Apr 9, 2009 at 4:12 PM
LA GANZA
  • 44 POSTS
yes the spark plugs are getting good spark how can make sure that the injector is working properly thanks
Apr 9, 2009 at 5:26 PM
BLUELIGHTNIN6
  • 16,542 POSTS
First just use a manual fuel gage to check pressure at the rail. If there isn't enough fuel pressure then the injectors wont receive fuel to burn. If OK here, test the injectors to see if they are getting signal to pulse. You can also use a mechanic stethoscope to listen to the injectors. You should be able to hear each one clicking with someone cranking engine or if engine will start, with engine running.
Apr 9, 2009 at 5:40 PM
LA GANZA
  • 44 POSTS
thanks for all you help , the injectors are working fine I can heart it. but cant get fuel pressure tester is any way the check the fuel pressure without tester.
Apr 10, 2009 at 12:53 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Ok. So plugs, wires, injectors all check out OK. We'll hold off on fuel pressure gauge for now. Check for vacuum hose splits, kinks or improper connections. Also check intake manifold for vacuum leak. You said the coils were good as well, so did you measure resistance? It should be 2.6 - 2.7 k/ohms. If it isn't then the ignition control module may be faulty.
Apr 10, 2009 at 3:07 PM
