1999 Honda Passport anti freeze leaking out....
1999 HONDA PASSPORT
147,000 MILES • 6 CYL • 4WD • AUTOMATIC
JSKIPPER
the anti freeze is leaking out sometimes. i checked the radiator and hoses but it is leaking from down under the truck and is like running down from motor somewhere. im not sure if the water pump is the problem or a hole in a hose up in there. it dont run hot or anything just leaks.
Apr 29, 2008 at 8:07 AM
  • 31,937 POSTS
Hi there,
The only way to see what is going on is to get a cooling system pressure test done, this will show up any external leaks, it is a good idea also to have it up on a hoist so you can see the hoses and pipes that are not that visible from above.
Mark (mhpautos)
Apr 29, 2008 at 10:19 AM
