1998 Honda Passport thermostat
ASPHALTASSASSIN
Engine Cooling problem
1998 Honda Passport 6 cyl Four Wheel Drive Automatic
whats the best route to pulling the t-stat? pull lower intake?
Dec 4, 2009 at 8:51 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Disconnect the negative battery cable.
Drain engine coolant from the radiator and engine.
Disconnect radiator hose from the inlet pipe.
Remove the thermostat housing, then remove the thermostat..
Dec 4, 2009 at 2:30 PM
