Front rotor replacement
145,000 MILES • 6 CYL • 4WD • AUTOMATIC
JSHRADER90
Do you have the process for replacing front rotors on my vehicle listed above?
Mar 31, 2009 at 12:52 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Here is a video and a guide of the job being done so you can see how to replace the brake rotors and pads:
https://youtu.be/XTuDGxH62F8
and
https://www.2carpros.com/articles/how-to-replace-front-brake-pads-and-rotors-fwd
Cheers
Mar 31, 2009 at 6:27 AM
ROASTER
This is not as easy as you were let on! I have a 1998 4WD Passport and according to the manual you have to indeed remove the caliper, but then you have to take out wheel bearings, yank the axle and a few other things just to get to the rotor assembly. It is detailed in the Haynes repair manual pretty well, but count on two to three hours per side and lots of parts laying around to get it done.
Jul 16, 2009 at 12:12 PM
TJQ
Does anyone know how complicated it is to replace the front brake rotors and pads on my vehicle 4WD? I have done GM's many times and they are pretty simple, however I am not quite sure what to expect with this vehicle. Any help would be appreciated. Thanks.
Jun 18, 2018 at 5:45 AM (Merged)
