1997 Honda Passport Clicking Starter
1997 HONDA PASSPORT
SCHMALTZY
Engine Mechanical problem
1997 Honda Passport Four Wheel Drive Automatic
I just replace the battery and alt. on my Passport last winter. Now I am having some problems with the starter.
I went to go start it this morning and all it would do was click ONCE. The lights were on bright and my battery gauge was showing full. So I tried it a could times. Turn it, click, turn it, click, about 5 times. Then the engine rolled over but only for about 1/2 a second, not long enough to start. Then I got a couple more clicks when trying to start it. Finally it started right up.
Is my starter going bad? Do I maybe have a loose connection somewhere? Where is the starter located on the Passport?
Dec 3, 2009 at 1:04 AM
MATHIASO
  • 1,209 POSTS
https://images.2carpros.com/forum/automotive_pictures/46384_0900c15280021474_1.jpg
The problem is the starter. (Follow the positiv battery cable, it will lead you to the starter.) To remove it, Disconnect the negative battery cable . Remove the heated Oxygen (HO 2 S) sensor connectors the exhaust front pipe The heat shield The starter wiring connectors and finally The starter motor NOTE: label any wire disconnected, to make installation more easier. To install it Install or connect the following: Starter motor. Tighten the bolts to 30 ft. lbs. (40 Nm). Starter wiring connectors Heat shield Exhaust front pipe Heated Oxygen (HO 2 S) sensor connectors. Negative battery cable. Hope this help.
Dec 3, 2009 at 1:55 AM
