1997 Honda Passport alternator
1997 HONDA PASSPORT
126,000 MILES • 6 CYL • 2WD • AUTOMATIC
JOE 61
alternator stoped charging checked battery cables with volt meeter to confirm found not working took alternator off took to parts store they checked said it was bad i put new alternator on car and it still will not charge checked fuseable links and fuses all are good checked charge wire on back of alternator to batterie for contnuity checked good what do i do next please help
Jan 16, 2008 at 2:12 AM
2CARPRO JACK
  • 11,533 POSTS
Did you check all fuses in both fuse/relay centers? The PCM controls the charging of that alt, but there are 2 fuses in the system as well. I take it that it wasnt putting out at the back of the alt either?
Jan 16, 2008 at 11:29 PM
