1996 Honda Passport what part is that P1860?
1996 HONDA PASSPORT
180,000 MILES • 6 CYL • 4WD • AUTOMATIC
CHEVMANZZ
I need to know about i already replaced EGR sensor( code was P0401) valve ( before was check engine on and now gone) after i drove about 100 mile after and now i see "check engine again and i went to autozone for me check scanner and found P1860 but they dont know what part..do you know what the parts name so i can go but and replace for her. she really cant affored so i am doing this for her free repair that her's income very low.. many thanks hope to hera from you. Thanks
Feb 20, 2009 at 6:09 AM
BLUELIGHTNIN6
  • 16,542 POSTS
P1860 TCC PWM Solenoid Circuit Electrical
Torque Converter Control Solenoid. ..It controls the lockup clutch in the torque converter. When it malfunctions the clutch can fail to engage or disengage properly causing shuddering at speed and stalling at idle. It is found inside the transmission as part of the valve body.
Thanks for using 2CarPros.com!
Feb 20, 2009 at 4:39 PM
CHEVMANZZ
where can i buy this part TORQUE CONVERTER CONTROL SOLENOID for honda 1996 passport.I tried look for parts and dont have it. where can i find the part? now it start the trans getting not getting second gear to engage ( sometime ).I am in north Nj
Thanks.
Mar 19, 2009 at 4:11 AM
BLUELIGHTNIN6
  • 16,542 POSTS
You may have to purchase from the dealer if you are having difficulties finding it at local part stores.
Mar 19, 2009 at 6:52 AM
CHEVMANZZ
what about if i send to repair to aamco transmission. how much do you thinks this gonna cost to do that repair? i will try to asked her take there to ammco to see. thanks again
Mar 19, 2009 at 10:23 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Honestly with it being a 4 wheel drive it is going to cost over $1,000 because the tranny has to be removed and disassembled so you may want to check around on having a new tranny installed instead of having yours rebuilt.
Thanks for using 2CarPros.com !
Mar 19, 2009 at 10:36 AM
