1996 Honda Passport valves
1996 HONDA PASSPORT
108,000 MILES • 6 CYL • 2WD • AUTOMATIC
NUCKLEJAMMER
Can the intake and exhaust valves for the 3.2L
V/6 be adjusted and if so, "how"
Thank you: Ron:
Mar 4, 2009 at 3:28 AM
RACEFAN966
  • 5,029 POSTS
This engine has hydrolic lifters and no valve adjustment can be made. Thanks.
Mar 4, 2009 at 7:23 AM
NUCKLEJAMMER
Are you telling me that I can't even shim to take out excessive gap between cam lobe and valve bucket.
Thank you - Ron:
Mar 5, 2009 at 2:44 AM
THIS IS MIKE
  • 686 POSTS
That is correct, they are not made to be adjusted.
You may have excessive sediment in the oil and that may be causing the valve train noise. Frequent oil changes seem to help.
Mar 5, 2009 at 6:56 AM
