1995 Honda Passport heater stoped working
1995 HONDA PASSPORT
15,300 MILES • 6 CYL • 4WD • AUTOMATIC
BILLLEE
Hi we just got this passport and we were driving around all day. It was runing really great no problems. But then i went to floor it an it went fine got up to seed very quick. Then I did it again I steped on it an right after I let off two lights came on my brake light and a battery light came on in the dassboard. Then i noticed my heater fan was off. Now nothing comes out of the vents the fan dont turn on an nothin comes out. Also the battery gage went down a little. We thought because of the battery light that came on the battery was bad so we went an bought a new one and put it in it did not make a difference. I checked all the fuses none were blown. What could of caused my heat to stop working and why did those lights come on?
Dec 18, 2007 at 3:43 AM
MERLIN2021
  • 17,250 POSTS
You have blown a fuse to make the battery light come on, and I think you should check the brakes! As the pads wear, fluid in the master is drawn into the calipers, when enough fluid is displaced, the light turns on!
Dec 18, 2007 at 5:01 AM
