1994 Honda Passport Won't start
150,000 MILES • 6 CYL • 4WD • AUTOMATIC
GENE RENE
When I went to start my car it made a very loud pop sound. Now it will not start. It only makes a clicking sound. Could it be the starter? What was the loud pop?
Dec 30, 2009 at 10:43 AM
KHLOW2008
  • 41,812 POSTS
Hi Gene Rene,
It is impossible to say what cause the pop noise.
Did you test the battery condition? The pop noise could be due to a short circuit in the battery.
Dec 31, 2009 at 1:53 AM
GENE RENE
I'm pretty sure the battery is good as everything electrical seems to work. What about the starter relay or the starter itself? All I get when I try to start is a clicking sound.
Dec 31, 2009 at 5:45 AM
KHLOW2008
  • 41,812 POSTS
Clicking noise could mean the battery is weak and not able to crank the starter.
Electrical components do not require much current to operate and a weak battery is sufficient.
If the battery is good, the clicking noise would be from the starter and that could mean it is bad.
Try jump starting to see if it works.
Jan 1, 2010 at 12:33 AM
