Occasionally when starting vehicle, turn key and nothing happens. Turn off then on again and it starts right up.
Feb 14, 2010 at 2:01 PM
✓Experienced Mechanic
Your probable causes here could be the starter, starter relay,transmission range switch and ignition switch-Double check battery connections and at the starter side-
