1994 Honda Passport 6 cyl Two Wheel Drive Automatic
Passport overheated. I replaced the fan clutch, thermostat and radiator. On idle the cars temps reaches half way up on gage but does not go past that point even if I bring the rpm’s up. Upper radiator hose gets hot and has a “bubbling" noise coming from it but the bottom hose stays cold. There is also some air that is being pushed back into the overflow. If I attempt to drive it the temp shoots up hot within a half mile? Is it possible that I have some kind of air bubble in the cooling system or do have something more serious going on?
SPONSORED LINKS
Tuesday, December 22nd, 2009 AT 12:29 PM
