1994 Honda Passport Lack of power going up hills
1994 HONDA PASSPORT
137,000 MILES • 4 CYL • 2WD • MANUAL
SLYDECKI
I recently had some hoses, thermostat and fan clutch replaced. The radiator is 2 yrs old. Original problem was thermostat was sticking. As soon as I got the car back I noticed I had lost power going from a stop, then shortly found out going up hill where normally I could go 5th gear 65-70. I had to downshift to 3rd just to stay at 60. I took it back and they tell me nothing is wrong. Im the only owner of the car and it 180 difference power wise than when I dropped it off. Any ideas of what might be going in? Also, check engine light goes on/off from time to time. But according to this shop nothing is wrong. I'll take it somewhere else, but maybe some insight as to what the cause might be would ve helpful. Thanks
Mar 1, 2010 at 10:32 PM
Inspect and test all the following listed below and get back with some results
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard.
Mar 2, 2010 at 11:42 AM
