2002 Honda CR-V Front Vibration
HONDA
PURSEC
I have a virbration in the front end when going over 25 or so. I can feel it in the gas pedal and the stiring whell shakes. It is only when I go striaght and doesn't last for more than 10 minutes. I have new tires, new rotars and brakes. I just had a PA inspection by Honda and I wonder if something didn't get put back properly? I have a 2002 honda CRV. 75,000 miles
Jun 28, 2007 at 6:29 AM
BRUCE HUNT
  • 3,754 POSTS
If it stops after a period of time it has to be something that gets warm or hot and the heat expands forcing the binding item away and then it cools and stops. First to mind is a hanging brake caliper. You might drive the car and right after it stops vibrating, check the wheel rotor for heat. Compare and see if first they get real hot or one is hot when the other is not.
Another thought is that even though you have new tires, a cord could be bad.
Jun 28, 2007 at 6:53 AM
PURSEC
I was thinking it had something to do with the brakes because I was sitting at a light htis morning and lifted my foot off the breake and it made that noise it make if you still have your foot partially on the brake. Will it just go away? Or should I take it in? Thanks so much for your help! Really appreciated and I will make a donation!
Jun 28, 2007 at 7:04 AM
BRUCE HUNT
  • 3,754 POSTS
Your choice. Since you just had the work done they should look at it and address it. If you find the excessive heat that I mentioned you might consider lubing the caliper system to free its movement again. Be mindful not to get any lubricant on the pads.
Jun 28, 2007 at 9:24 AM
Suggested Repair
Have the shop that recently did the brake work recheck the front brakes. After the vibration stops, compare rotor temperatures for a dragging or hanging caliper. If one side is excessively hot, lubricate the caliper slides so it moves freely, keeping lubricant off the pads. Also consider a separated tire cord despite the new tires.
Conversation Summary
The owner of a 2002 Honda CR-V with 75,000 miles reports front-end vibration above about 25 mph that is felt in the gas pedal and steering wheel, occurs only when driving straight, and lasts no more than 10 minutes. New tires, rotors, and brakes were recently installed, and a Honda inspection was just completed. The expert suggested a heat-related binding issue, especially a hanging brake caliper, and advised comparing rotor temperatures right after the vibration stops. A bad tire cord was also mentioned. The owner noted a brake-like noise when releasing the pedal and was advised to have the recent work rechecked; if excessive heat is found, the caliper system can be lubricated without getting lubricant on the pads.
