TROUBLE WITH MY CAR I JUST GOT
HONDA
TOWENS
I HAVE A 1992 ACURA LENGEND MY CHECK ENGINE LIGHT AND ABS LIGHT STAYS ON. I HAVE BLUE OR GRAY SMOKE COMMING OUT OF THE EXHAUST WHILE I AM DRIVING AND SOMETIMES WHILE I AM SITTING STILL IN PARK. WHAT SHOULD I DO?
Feb 6, 2006 at 1:32 PM
TOWENS
[quote:795f229cce="towens"]I HAVE A 1992 ACURA LENGEND MY CHECK ENGINE LIGHT AND ABS LIGHT STAYS ON. I HAVE BLUE OR GRAY SMOKE COMMING OUT OF THE EXHAUST WHILE I AM DRIVING AND SOMETIMES WHILE I AM SITTING STILL IN PARK. WHAT SHOULD I DO?[/quote:795f229cce]
FISHERMAN
  • 937 POSTS
You have to retrieve the codes from your computer, your car has a bad sensor could be the oxigen sensor, the ABS light its related to the absolute braking sistem, which its another issue, i dont think its related with the "check engine light" first at all got an a scanner tool or rent it and retrieve the fault from the on board computer that its going a tell you whats its wrong.
Manuel.
Feb 7, 2006 at 4:04 AM
DTMFZR
  • 9 POSTS
your ABS system is probably leaking or the pump is bad. the system is kept pressurized, and has a small pump. the pump/accumulator/modulator is usually one part, and kinda expensive. check for leaks first.
Feb 7, 2006 at 11:36 PM
