Timing Belt
NATTYB4KSU
  • HONDA
Do I need to replace my timing belt, if the rotor underneath the distributor cap is not spinning
Friday, May 26th, 2006 AT 1:56 PM
LOSONE
  • 1,616 POSTS
If the distributer gear is good you will have to replace a lot of things including the cyl head because the engine is an interference engine and a broken timimg belt wipes out the valves. Good luck
Friday, May 26th, 2006 AT 6:16 PM
NATTYB4KSU
  • 5 POSTS
Is there a way to check if the distributor gear is good? If I have to replace all those parts, considering how old my car is, should I just look to get a new one? Thanks for all your help.
Friday, May 26th, 2006 AT 10:36 PM
LOSONE
  • 1,616 POSTS
You didn't provide me the make, model, year and mileage of your car so I can't make an accurate judgement.
If the engine spins over like you have no spark pulgs in the holes then it is a broken timimg belt You can remove the valve cover and see if the valves move when you turn over the engine.
As a reminder, the timing belt replacement on most Hondas is 60K on earlier models and 90K on newer models.
Good Luck
Saturday, May 27th, 2006 AT 1:18 PM
