1994 Honda Stripped Rotor Screw Fix
HONDA
PREDWINE
When trying to remove a rotor to replace it on the 1994 Honda DX, I stripped one of the screws when trying to remove it with a drill (in adition to the two caliper mounting brackets, there are 2 screws that need to be taken off). I successfully installed the one on the driver side (the one the was the worst). What do I need to do to get the other one taken off? Thanks, Paul
Feb 19, 2007 at 5:15 AM
GARFIELD
  • 197 POSTS
once you get the other screw off you can helicoil the damaged hole.
Feb 22, 2007 at 12:12 PM
CHEVY22
  • 1,375 POSTS
when you say screws do you mean the two small bolts in the center of the rotor?? if so and the heads are stripped try using a small chisel moving it in the direction the screw needs to go clockwise , let us know
Suggested Repair
If the small rotor retaining screw heads are stripped, use a small chisel to drive the screw in the loosening direction until it comes out. Once the screw is removed, the damaged hole can be repaired with a helicoil.
Conversation Summary
The owner of a 1994 Honda DX stripped a rotor retaining screw while replacing a rotor and asked how to remove the remaining screw. One expert suggested using a small chisel on a stripped screw head to turn it loose. Another said the damaged hole can be repaired with a helicoil after the screw is out.
