Honda Low Brake Pedal After Pads
HONDA
CIVICUSER
  • 13 POSTS
I just replaced my front brake pad about 3 weeks ago. when my brake pads were replaced, they seemed fine and sharp and you don't not apply the brake pedal very deep to stop the car.
But after about 3 weeks, I would have to apply my brake pedal very deep to stop my car and the brakes doesn't seem as sharp as when they were just replaced.
I check the brake fluid, it is still near full. What seem to be the problem? and how to fix it?
Nov 7, 2006 at 6:46 PM
BRUCE HUNT
  • 3,754 POSTS
Sometimes when you put on the brake pads the fluid is backed up in to the resevoir as a result of compressing the caliper. This pushes the fluid back in to the master cylinder or resevoir. So...look at the fluid to see if it is overfilled. Secondly, I would crack the bleeders on the system to see if there is any air in the system. Next, if that doesn't take care of things I would examine the master cylinder. It could be weak.
Nov 8, 2006 at 2:16 AM
Suggested Repair
Check whether the brake fluid reservoir is overfilled from compressing the calipers during the pad job. Bleed the system to remove any air, and if the low pedal remains, inspect the master cylinder for weakness.
Conversation Summary
After front brake pads were replaced, the Honda's pedal was firm, but about three weeks later it had to be pressed very deep and the brakes felt less sharp. Fluid level was still near full. The expert said compressing the calipers can push fluid back into the reservoir, so check for overfill, bleed for air, and if needed examine a weak master cylinder.
