Squeaking on the throttle body.. help!!
HONDA
OAKLEYBEING
1993 Other Honda Models 6 cyl Automatic 80000 miles
Will it need to be replaced? Or is there something I can do to stop it from making the noise. I thought it might be coming from the air intake, maybe one of you guys could help? Thanks alot
Aug 12, 2008 at 3:22 PM
  • 31,937 POSTS
Hi there,
If the throttle body is worn and the throttle shafts are worn i would be replacing the unit, you can clean the body with a throttle body cleaner, but if the shaft is worn you best fit a new unit.
Mark (mhpautos)
Aug 12, 2008 at 3:44 PM
