Honda Maintenance Light On
HONDA
SWEETDOUGH58
Hello;
Could you please give me the information on how to reset the maintainace light on Honda Ex V6 4doors?
Thank you,
Sweetdough58
Jun 10, 2007 at 2:06 PM
BRUCE HUNT
  • 3,754 POSTS
On some older models you push the key in to a slot on the dash to reset. Later models that I know of use the following. Key off push and hold the reset on the trip odometer. Turn on the ignition but don't start the car. Hold the reset in until the maintenance light goes out. Release and that should take care of it. The is information about this in the owner's manual.
Jun 11, 2007 at 2:34 AM
Suggested Repair
With the key off, press and hold the trip odometer reset, then turn the ignition on without starting the engine and hold until the maintenance light goes out. On some older Hondas, insert the key into the dash reset slot. Confirm the procedure in the owner's manual.
Conversation Summary
The owner asked how to reset the maintenance light on a Honda EX V6 four-door. The expert said some older models use a key slot on the dash, while later models are reset by holding the trip odometer reset, turning the ignition on without starting, and holding until the light goes out. The owner's manual also covers the procedure.
