1991 Honda Civic Knocking in Reverse
MY_LIL_HONDA
Hello! Just me again!
When I was reversing my car today, braked to stop reversing.... i heard a knocking sounds. Any ideas?
Apr 2, 2006 at 8:25 PM
LOSONE
  • 1,616 POSTS
Give me a little more info about the car--engine--tranny type mileage etc. Without more info it sounds like it might be a motor mount issue. Probably from driving on the wrong side of the road Ha! Ha!
Let me know
Apr 3, 2006 at 12:27 AM
MY_LIL_HONDA
My car is a Honda Civic, automatic transmission, 1991 make, mileage 118550. We recently replaced battery as well. HAHA! Wrong side of the road!
Hope this helps!
Apr 3, 2006 at 3:15 PM
LOSONE
  • 1,616 POSTS
That makes it a little clearer with an automatic. The Honda doesn't like to be put in reverse unless you are at a dead stop.
Do you hear the knocking sounds when you are in park or neutral? Do you hear them when you are accelerating slowly? Because the engine and tranny are bolted together under the bonnet. I am trying to isolate if the sound is engine or tranny.
Do one test for me. Open the hood, and watch the engine as you slowly rev it in neutral. Does it tend to shift or stay still?
Have someone in the car and put it in Drive. With the foot on the brake, increase the engine RPM and see if the engine "picks up." Do the same in Reverse. I am trying to determine if there is a broken motor mount.
If the engine "picks up" then there is a broken motor mount. They can make a nasty knocking noise as the engine/tranny bounce along on a broken support.
Let me know
PS I will be out of town from 5 Apr to 10 April visiting siblings.
Apr 4, 2006 at 12:41 AM
MACAT
  • 17 POSTS
could be loose muffler clamps. check it out.
Jun 6, 2006 at 4:22 PM
Suggested Repair
Check the motor mounts for a broken support by watching whether the engine shifts when revved in neutral and when loaded in Drive and Reverse with the brake applied. Also inspect the muffler clamps for looseness.
Conversation Summary
A 1991 Honda Civic automatic with about 118,550 miles made a knocking sound when the driver braked while reversing. The expert suspected a broken motor mount and suggested tests to see if the engine moves under revving or load in Drive and Reverse, and whether the noise occurs in Park, Neutral, or during slow acceleration. Another reply suggested checking for loose muffler clamps.
