1995 Honda Odyssey AC Cuts Out
HONDA
KEMERICK814
My 1995 Odysey w/ 173000 miles AC cuts out without notice from time to time for no apparent reason. It can cut out in the midst of operation or it can fail to cool from the start. It will, however, always start to cool again (after failure) when it sits for several hours at rest. The strange part is that the rear AC always works and never cuts out or fails to operate. We had the compressor checked and it's not leaking. The AC blows a frosty 45 degrees when operating correctly. I have been told it is probably an expansion valve malfunctioning. I'd like to know if that sounds feasible before I order the part and start to repair it. Also, what are some of the other possible problems and what are the caveats you'd give an amateur mechanic before attempting the repair himself?
Apr 18, 2006 at 10:36 AM
LOSONE
  • 1,616 POSTS
hummm, Do you have an LX or EX? There is an ambient air temperature sensor in the front ac evaporator housing that may be the problem. Also your vehicle has an A/C amplifier that could be the problem Good luck
Apr 18, 2006 at 11:00 AM
Suggested Repair
Check the ambient air temperature sensor in the front A/C evaporator housing and the A/C amplifier. Confirm whether the Odyssey is an LX or EX before replacing parts; the expansion valve was not confirmed as the cause.
Conversation Summary
The owner of a 1995 Honda Odyssey reports that the front A/C intermittently stops cooling, either while running or from startup, then works again after sitting for several hours. The rear A/C always works, the compressor is not leaking, and cooling reaches about 45 degrees when operating. The expert asks whether it is an LX or EX and suggests the ambient air temperature sensor in the front evaporator housing or the A/C amplifier as possible causes.
