Honda CRV 1998 (uk) Clock not illuminated
1998 HONDA
IAN TAN
can anyone tell me how to change the bulb for the digital clock. i have checked all the fuses which are ok. but it looks as if the small clock panel insert should just prise out but i only seem to be mashing it up as i try to do it. surely the whole dash doesent have to come out! nothing at all is mentioned in the manual or my chiltons repair manual?? thank you in advance to anyone with the information
Apr 14, 2007 at 9:43 PM
CARBOY
  • 14 POSTS
The clock readout is an LED (light emitting diode) array and has no conventional bulb. Mine went out on my 1999 CRV. I think I pried it out by sticking something in the top of it and prising. The circuit board has a single chip on it and some supporting components, along with the readout. The chip had all the correct voltages to work. I guess it just quit.
Apr 20, 2007 at 11:11 AM
IAN TAN
Carboy
THANKYOU, what did you have to do. persumably buy a new one? or did you manage to repair it?
tks Ian
Apr 20, 2007 at 6:52 PM
CARBOY
  • 14 POSTS
I haven't done anything with the clock at this time. I popped it back into its opening several months ago when I was checking out the circuitry. I suppose I will eventually buy a new one. Haven't priced them yet. I may also take the thing back out and see if there are any part numbers on the integrated cirucuit "chip" and see if it can be purchased easily. Then I would get out the old magnifying glass, soldering iron with a very small tip, and try to repair it. Don't know when I'll have time for all that though!
Bob
Apr 21, 2007 at 2:40 PM
IAN TAN
Bob,
Thank you again, if/When you get the chance Please let me know how you got on. So you think prising out from the top should do the trick? I will price one up and if i find out anything will let you know. Tks again. Ian
Apr 21, 2007 at 6:28 PM
CARBOY
  • 14 POSTS
I spent some time refamiliarizing myself with getting the clock out. What you do is insert something thin yet unflexible under the center AC vent and pry (prise) down which raises the bottom of the vent up. You may have to move your prising tool left and right to help things along. The vent sort of hinges at the top with the springy retainers at the lower edge. The wires going to the clock and the 4-way flasher switch can now be carfully unplugged. Once you have the vent assembly in your hand, you can undo the phillips-head screws and remove the clock. I priced a clock here. It is around $232 US. Honda sure is proud of it! So I guess I'll get the time some other way............Bob
Apr 24, 2007 at 2:25 PM
SATITUS
I also offer a CRV repair service (as well as many other vehicles including foresters, 4runners, pathfinders, camrys, corollas, etc). Check out my site
www.autoclockrepair.com
Mention this ad and get it fixed for 20% off list!
Thanks!
Jan 17, 2010 at 10:35 AM
