honda clutch
HONDA
JOEJOE530
i have a 1988 honda 5 speed stick shift,when the car is started up i push the clutch in and it wont shift into first second,third,fourth,or fifth and even reverse,so i turned it off then put it in first then when i started it up again it wants to take off even though the clutch is still engaged,could i be low on gearcase oil,or could it be the prssure plate
Jul 2, 2007 at 1:48 AM
BRUCE HUNT
  • 3,754 POSTS
Is that a cable or hydraulic system. That clutch is not right and it could be a cable adjustment or it is time for a clutch replacement. Check the cable first.
Jul 2, 2007 at 2:14 AM
