Honda 1998, 4cyl,180,000. I have a problem cold starting and also happens after the car has gotten up to temp, sits, for 2hrs and happens again. The engine starts but seems to be missing for approx 10 sec then rpm jumps to 1000 and the car idles fine and runs fine after that. I did get both temp sensors replaced and injectors cleaned. Wires and distributor cap are new. This all started after I blew a top radiator hose and check engine lite came on. Also have replaced timing belt at corret intervals and changed water pump.
Mar 25, 2007 at 10:51 AM
