1998 Honda Cold Start Miss
You could have a fuel pressure check done. A drop in fuel pressure could be the cause of the starting problem. There are other things as well. EGR valve, etc.
Suggested Repair
Pull diagnostic codes. Confirm the coolant is full and the cooling system has been bled of air. Have fuel pressure checked for a drop that could cause the brief miss, and consider the EGR valve if those checks are normal.
Conversation Summary
The owner of a 1998 Honda 4-cylinder reports that the engine misses for about 10 seconds on cold starts and after sitting roughly two hours when hot, then the RPM rises and it idles and runs normally. Temperature sensors, injectors, wires, distributor cap, timing belt, and water pump were already addressed; the problem began after a radiator hose failed and the check-engine light came on. The expert recommends pulling codes, verifying coolant level and air bleeding, and checking fuel pressure, with the EGR valve among other possible causes.
