High presure in the coolling system
HONDA
CHIN
THE ACURA LEGEND IS A 1992 WITH 215K MILES THE THING IS THERE IS HIGH PRESURE IN THE COOLLING SYSTEM. THE TOP HOSE GET VERY BLOATED WHEN THE CAR IS DRIVEN A FEW MILES AND PLUS THE COOLANT IS LOW BY THE TIME I CHECK THE RAD. I PUT A AFTER MARKET RADIATOR IN THE CAR. THE SYMPTOM HAS NOT CHARGE. I HAD TO PUT A NEW RADIATOR BECAUSE THE OLD ONE HAD A CRACK ON THE TOP. THIS PROBLEM STARTED WITH THE NEW RADIATOR
Mar 18, 2007 at 5:21 AM
KIN CHAN
  • 453 POSTS
u might had over heated ur mtr and have a blown head gasket...take it to a shop and do a block test ..or else u can buy the tester kit from an auto parts store and do it urself..but professional use 5 gas analyzer and pressure tester --> almost 99% on the money...do it urselfer kit its less accurate...goodluck man
Mar 18, 2007 at 8:11 AM
BRUCE HUNT
  • 3,754 POSTS
Start the car with the hood open, radiator cap off the vehicle and add coolant as needed to the radiator. Is there serious bubbling in the radiator. That first radiator I suspect was broken because of pressure in the system. If you see bubbling going on there is a head gasket problem.
Mar 19, 2007 at 6:06 AM
