Honda Fuel Injector Leak
HONDA
LUCYB64
my fuel injector is leaking gas or fuel, whatever,my question is , some says my injector needs replacing, some says just the rubber part needs replacing, what do you guys think
Apr 25, 2006 at 10:10 AM
BRUCE HUNT
  • 3,754 POSTS
Does it leak where the injector enters the intake manifold? If yes, the o rings need to be replaced.
Apr 26, 2006 at 7:32 AM
LUCYB64
[size=18:d696950c8d][/size:d696950c8d]the o ring? or do i need to replace the whole injector. i see the leak marks .
Apr 26, 2006 at 9:27 AM
BRUCE HUNT
  • 3,754 POSTS
Gently take off the metal retaining clip on the injector with the help of a small screw driver. Now unplug the wire from the injector. Gently with a slight twisting motion pull the injector out of the intake assembly. Now you will see a small build up of carbine on the tip but you will also see the small o ring on the injector. Replace it.
Apr 28, 2006 at 6:28 AM
Suggested Repair
If the injector leaks where it enters the intake manifold, replace the injector O-ring rather than the whole injector. Remove the retaining clip, unplug the connector, gently twist and pull the injector out, and install a new O-ring.
Conversation Summary
The owner of a Honda reported a leaking fuel injector and asked whether the injector or only the rubber seal needed replacement. The expert said a leak where the injector enters the intake manifold means the O-ring should be replaced, and described removing the clip, connector, and injector to access and replace that seal.
