Honda Oil in Spark Plug Wells
HONDA
BEBA1965
My car began overheating and ticking like I had a bad piston. When I popped the hood, I noticed that the sparkplug wires were blown away from the block and there was oil all over them. What would cause this and is it repairable ?
May 3, 2007 at 11:05 AM
BRUCE HUNT
  • 3,754 POSTS
Some confusion in what you said but I take it that a couple of the wire were disconnected from the plugs and there was oil on the wires and in the spark plug holes, correct? If so, the wires were easily lifted off even by air flow. The oil in the plug holes is the problem. You will need to take off the valve cover, replace the valve cover gasket most likely and then replace the grommets on the plug holes. These are what stop the oil from getting in to the holes. Dry up, gently, the wires and if there is any engine misfire you may need to replace the wires.
May 4, 2007 at 3:21 AM
Suggested Repair
Remove the valve cover and replace the valve cover gasket and the spark plug hole grommets that keep oil out of the wells. Gently dry the plug wires, and replace them if the engine misfires.
Conversation Summary
The owner reported overheating, a ticking noise, spark plug wires displaced from the engine, and oil on the wires. The expert said oil in the plug holes likely let the wires lift off easily and recommended replacing the valve cover gasket and plug-hole grommets, then drying the wires and replacing them if misfire continues.
