1992 Acura Integra High NOx
HONDA
STAFFORDSHIRE1
I own a 1992 Acura Integra LS with 180,000 miles,
5 speed manual trans.
The car still runs great except for 1 thing, I failed
inspection for NOx. All the other emission tests passed with flying colors. The CO & HC count were
excellent. The NJ State standard for NOx is 1088,
and my reading was 1318. I checked the VECI label
under the hood & it does not specify that my car has
an EGR system.
Apr 14, 2006 at 6:07 AM
LOSONE
  • 1,616 POSTS
Some people think the Acura EGR Valve is no big deal. The Acura Integra EGR Valve is just there because the government says so and that Acura EGR Valve doesn’t really do much.
They sometimes ignore the Acura EGR Valve and even sometimes remove it. And they wonder why their vehicle doesn’t run the way it should. As with all cars, trucks, vans and SUVs, the Acura EGR Valve is housed on the intake manifold to permit a measured amount of exhaust gasses back into the engine.
This is a good thing as the Acura EGR Valve helps your vehicle meet emission testing standards and reduces knock. It is very important that you buy only the application specific Acura EGR Valve for your vehicle’s combination of engine, model and year.
One more thing, ignoring a faulty Acura EGR Valve can cause major problems. Remember, the Acura EGR Valve help keep fuel from detonating in the cylinder … exploding rather than quickly burning as it should. If not replaced a faulty Acura EGR Valve can quite literally cause hundreds if not thousands of dollars in damage and increase NOX in the exhaust.
I hope this helps Good Luck
Apr 14, 2006 at 10:18 AM
Suggested Repair
Inspect the EGR system and replace a faulty EGR valve with the application-specific part for this engine, year, and model. A bad EGR valve can raise NOx and may also cause knock or engine damage.
Conversation Summary
The owner of a 1992 Acura Integra LS with 180,000 miles failed a New Jersey inspection for high NOx (1318 vs. a 1088 limit) while CO and HC passed. The underhood VECI label does not list an EGR system. The expert explained that the EGR valve meters exhaust gas into the intake to reduce NOx and knock, and advised using the correct EGR valve rather than ignoring or removing it.
