check engine light codes p0301 and p0303
HONDA
EDRATH@SWBELL.NET
i have a 1997 acura cl 2.2l with 160,000 miles. im getting a check engine light which blinks every so often. codes p0301 and p0303 appear which are ignition misfire for cylinger 1 and 3. Ive replaced plugs, wires, distributer and rotor. what else could cause codes to keep coming back.
Apr 26, 2006 at 12:29 PM
BRUCE HUNT
  • CERTIFIED EXPERT
  • 3,754 POSTS
The codes keep coming back but have you then cleared the codes?
Apr 26, 2006 at 2:33 PM
EDRATH@SWBELL.NET
yes i removed negative battery cable for 10 minutes, had the codes reread now i only have p303.
Apr 26, 2006 at 3:40 PM
BRUCE HUNT
  • CERTIFIED EXPERT
  • 3,754 POSTS
Here is a list of possible causes:
Faulty spark plug or wire
Faulty coil (pack)
Faulty oxygen sensor(s)
Faulty fuel injector
Burned exhaust valve
Faulty catalytic converter(s)
Running out of fuel
Poor compression
Defective computer
Possible solutions:
If there are symptoms such as the engine is stumbling or hesitating, check all wiring and connectors that lead to the cylinders (i.e. spark plugs). Depending on how long the ignition components have been in the car, it may be a good idea to replace them as part of your regular maintenance schedule. I would suggest spark plugs, spark plug wires, distributor cap, and rotor (if applicable). Otherwise, check the coils (a.k.a. coil packs). In some cases, the catalytic converter has gone bad. If you smell rotten eggs in the exhaust, your cat converter needs to be replaced. I've also heard in other cases the problems were faulty fuel injectors.
You haven't mentioned whether there are any problems with the running of the engine. But look through the above.
Apr 26, 2006 at 4:23 PM
