1986 Acura Legend Driver Side Slip
1986 HONDA
JLANG
My Acura has about 208,000 I have recently replaced both axles but still feel a slipping or a gear stripping from the driverside is this coming from the inside of the transaxle[/i][/b]
Feb 28, 2006 at 4:56 AM
BRUCE HUNT
  • 3,754 POSTS
You replaced the transaxles, correct? If that is the case and you replaced them yourself, was the problem there before the replacement? If not, are they seated in to the tranny all the way? If they are seated and you still experience the slipping and grinding, your manual? tranny is in need of replacement.
Mar 3, 2006 at 9:20 AM
Suggested Repair
Confirm the replacement axles are fully seated in the transmission. If they are seated and the driver-side slipping or grinding continues, the transmission needs replacement.
Conversation Summary
The owner of a 1986 Acura Legend with about 208,000 miles replaced both axles but still feels slipping or gear stripping on the driver side and asks whether the problem is inside the transaxle. The expert asks whether the issue existed before the axle work and whether the axles are fully seated. If they are seated and the slipping or grinding continues, the transmission needs replacement.
