89 acura integra
1989 HONDA
HITEK
  • 30 POSTS
You said you have fuel, how about spark? 8)
Feb 11, 2006 at 3:37 PM
RYAN KINGSTON
new fuel pump installed, stopped for gas, 91 octane, wouldnt start, caught once, then promptly died, eventually started long enough to get me home, now impossible to start. cant hear the fuel pump click upon turning ignition, sound familiar? have had a TON of work on it recently, clutch, tranny, heads, axles, muff, you name it.
Feb 11, 2006 at 3:13 PM
HITEK
  • 30 POSTS
RYAN KINGSTON
i have spark, havent broken out the voltmeter but i am pretty sure that there is no current to the fuel pump, that was the last thing replaced and there is no sound coming from it upon ignition.
thx for responding :shock:
Feb 14, 2006 at 9:44 AM
FISHERMAN
  • 937 POSTS
Original fuel pump or replacement?
Did you check the pump relay and fuse?
Feb 15, 2006 at 1:10 AM
RYAN KINGSTON
new fuel pump, chekt fuses, seem okay, tho i am going to go thru it more thoroughly this weekend. it has been sitting in this mechanics lot for 2-3 yrs, tank not flushed, mr mechanic said probly not necessary, but new fuel pump wood be. all new clutch work, tranny tweex, oil pump, machined heads frum the original messt up oil pump replacement attempt. am very sik of throwing money at this car...seriously thx for the feed back :x
Feb 17, 2006 at 3:04 PM
