1999 Other Honda Models Starting
1999 HONDA
MARKGUSA
Engine Mechanical problem
1999 Other Honda Models 6 cyl Two Wheel Drive Manual
Hi I already have change the ignition coil and also have change new engine gasket but my honda city still wont start
Jun 29, 2008 at 7:44 PM
  • 75,988 POSTS
If the engine's condition is in tip top shape-do below to determine if its fuel or spark problem that's if its cranking over and refuses to start
Get a carb cleaner and spray into the carb or the throttle body on an EFI. Did it start and die? If not disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel problem, check the fuel pressure to rule out the fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil,distributor pick-up coil, ignition control module, cam and crank sensors-
If both fuel and spark is present-check the valve and ignition timing, this will lead you to problems with compression and valves opening and closing at the wrong time
Jun 30, 2008 at 2:17 AM
