1993 Saturn SC2
1993 HONDA
CUJO89
I was wondering if you could give me step by step information on how to install an alternator on the satrun.
Im use to Honda's. so im a little lost and cant find the information anywhere else.
Thank you
Mar 4, 2007 at 10:57 AM
MIKE H R
  • 3,094 POSTS
detach the negative side of the battery terminal, raise and support it on jackstands. working under the car remove starter brace if equiped, remove the two bolts holding the starter in place. the top one has to be removed from the engine compartment. partly lower the starter to get to the wires on the starter solenoid terminals. remove the starter from the engine. install in reverse
Mar 4, 2007 at 12:25 PM
