1991 Other Honda Models how to take a rotor off of a honda
1991 HONDA
BRENDA12
Brakes problem
1991 Other Honda Models 4 cyl All Wheel Drive Manual
need to know how to take off a rotor to a honda accord dx 1991. pls
Apr 16, 2009 at 8:03 AM
KHLOW2008
  • 41,812 POSTS
Hi brenda12@3,
You would need to remove the bearing with hub from the knuckle assy.
Remove CV shaft spindle nut.
Disconnect lower arm ball joint.
Separate CV shaft from knuckle assy.
Remove 4 holding bolt from reat of knuckle.
Tap bearing assy to release it from the knuckle.
Remove the 4 holding bolts of rotor.
Apr 17, 2009 at 8:58 AM
