The water pump seized and snapped the timing belt while accelerating in 2nd gear. It has an aluminum (aluminium) block. The front crankshaft pulley nut appears very tight. Is it counter rotating or normal? What is the best way to loosen it?
Also, it is a 12 valve, will there be any valve damage?
The engine has done 300,000 km and has never been opened.
thank you,
Ken
thank you,
Ken
Apr 30, 2007 at 7:26 PM
