1987 Honda Inconsistent Start and Idle
Suggested Repair
If the gas pedal must be held until the engine runs normally, it may be getting too much fuel. Check for a dirty air filter, wrong spark plugs, weak ignition, or a disconnected spark plug wire, and have the car scanned for codes. Also confirm why the oil pan was replaced, such as a leak or stripped drain-plug threads.
Conversation Summary
The owner of a 1987 Honda with about 158,000 miles reports inconsistent starting and idle after a tune-up for a choking carburetor and an oil-pan replacement. It sometimes starts normally, once failed to start in extreme cold, and can run at high or low RPM. Lately it shakes and idles very low until the gas pedal is held for about a minute, then idles normally. The expert said this suggests too much fuel and recommended checking the air filter, spark plugs, ignition, and plug wires, plus scanning for codes.
