Honda Odyssey
ELECTRICIAN
  • HONDA ODYSSEY
My Daughter's 1995 Honda Odyssey will not start.
I tried to check the fuel pressure but I didn't have the proper fitting for the fuel rail. My make-shift adapter leaked a little, but I still read 30 PSI. I suspect that 35 PSI is minimum. I got my old timing light to flash from all 4 ports on the distributor. The spark plugs looked worn out, so I regapped them to.040. I turned over the engine while squirting starting fluid in the intake runner and got nothing. The compression was 85, 65, 65, 65 PSI. This van has 166239 miles on the 4 cylinder motor. Any ideas?
P.S. If your answer helps, I will gladly donate.
Thank you,
Glen
Wednesday, August 15th, 2007 AT 6:45 PM
ELECTRICIAN
Monday, September 3rd, 2007 AT 8:21 AM
