The turning signal and hazard sounds, back up camera alerts all muted?
37,000 MILES
FLIGHTS5628
  • 12 POSTS
Hello!
I have the vehicle listed above Touring that the turning signal, hazard lights and also back up camera alert sounds all don’t function!
I’m assuming it’s a problem with a fuse, but I’m not sure as I don’t have schematics!
Any help would be appreciated!
Nov 12, 2024 at 12:04 AM
  • 55,677 POSTS
The warning systems all go through the BCM which might be having an issue, I would disconnect the battery overnight to help reboot the system. Also, check fuse # 34 and fuse EA in the fuse panel on the left side of the dash.
Here is a guide to help:
If the fuses are good and the battery disconnection does not work, I would run a CAN scan. You can get a CAN scanner (Controller Area Network) which will work on most cars from Amazon.
Here is a video to show you how:
https://youtu.be/u-4syLc-ifQ
Here are the fuse locations to help you. Check out the images (below). Please let us know what happens. Here are the warning system wiring diagrams so you can see how the system works.
Nov 12, 2024 at 9:21 AM
FLIGHTS5628
  • 12 POSTS
Wow. Amazing response.
Thank you!
Will try today and get back to you!
Nov 12, 2024 at 7:27 PM
  • 55,677 POSTS
You are welcome :) let me know what happens.
Nov 13, 2024 at 12:27 AM
FLIGHTS5628
  • 12 POSTS
I went under the dash and tested the 2 fuses you mentioned #34 and “a”. Both were fine. I then went to the legend at the side of the car and saw 2 20-amp fuses named audio amp. Looked at their sockets and both were empty. So naturally I went and bought 2 20-amp fuses and replaced them. Still nothing lol I also noticed that the rear side door for the passengers doesn’t make a sound either. Maybe another fuse is bad? Or missing?
For reference I’ve added all the other fuse holders under dash.
Nov 13, 2024 at 6:05 AM
FLIGHTS5628
  • 12 POSTS
Just wanted to repeat the problem again:
All the functions of the car appear to work perfectly. Only problem is no sound alerts from what seems like behind the steering wheel (for when I use my turning signals or backup camera, or side sliding door). My car radio audio is fine. The sound adjustment for Bluetooth works as well as other settings- I can hear them just fine.
Nov 13, 2024 at 6:09 AM
FLIGHTS5628
  • 12 POSTS
Also, my car alarm seems to function just fine!
Could it be just the speaker is bad at the dash?
Nov 13, 2024 at 9:03 AM
  • 55,677 POSTS
Thanks for the images. The sounds alerts come from the radio speakers, and since you say the radio works, I think the BCM has gone out, but we should do the CAN scan now which should report a code for the BCM to confirm the issue. Please go over my first post to see how to do the scan. Here is how to replace the BCM which you can get a preprogrammed unit by searching Google or Ebay in case a code is present for it. Check out the images (below). Let us know how it goes.
Nov 14, 2024 at 2:01 AM
FLIGHTS5628
  • 12 POSTS
Thanks for your reply.
You believe that turning signal sounds come from the radio speakers? I thought there was a speaker behind the steering wheel that makes the dedicated sounds for turning signals and other alerts.
Nov 14, 2024 at 2:32 AM
  • 55,677 POSTS
Sorry, I guess they do have a small speaker integrated into the instrument cluster which is driven by the radio. Here is what is said:
"The warning chimes typically originate from the vehicle's audio system, specifically through a small speaker or sound transducer located behind the dash or integrated into the instrument cluster."
This should have come up in the CAN scan.
So, it looks like this sound transducer has gone out inside the cluster which will need to be swapped out, you can get a preprogrammed unit by searching Google or Ebay. Here is how to swap the cluster out to help fix the problem. Check out the images (below). Please let us know what happens.
Nov 15, 2024 at 1:18 AM
FLIGHTS5628
  • 12 POSTS
Wow.
Thank you so much!
Before I order and re-program the new cluster, I wanted to check the transducers wires to see if they read a resistance, or if they are open. Would you by any chance have the wiring schematics for the sound transducer in the dash? And. if the wires go to where all the fuse boxes are under the steering wheel? I’m thinking maybe something happened to one of the pins or something was disconnected.
Thank you again for all your help.
I really appreciate you!
Nov 15, 2024 at 3:23 AM
FLIGHTS5628
  • 12 POSTS
I will try to run a CAN scan as well today!
Nov 15, 2024 at 3:24 AM
  • 55,677 POSTS
I don't have the circuit board diagram, but I do have the wiring diagrams for the cluster if that can help. Check out the images (below). Let us know how it goes.
Nov 16, 2024 at 1:39 AM
FLIGHTS5628
  • 12 POSTS
Thank you, my friend.
Nov 16, 2024 at 1:51 AM
  • 55,677 POSTS
You are welcome, have a good weekend!
Nov 16, 2024 at 1:54 AM
FLIGHTS5628
  • 12 POSTS
I looked at the wiring diagrams and I see 4 places that the gauge has a wire running to sound systems. Unfortunately, it just says the wire goes to “sound systems”. Do you by chance have the wiring diagram of the sound system that comes from the cluster? I’ve attached the photo you sent me circled in red all the points of mention of “sound systems”.
Thanks again
Nov 16, 2024 at 2:03 AM
FLIGHTS5628
  • 12 POSTS
Here is the photo.
Nov 16, 2024 at 2:05 AM
  • 55,677 POSTS
Sure, here is the sound system wiring diagrams, Check out the images (below). Please let us know what happens.
Nov 18, 2024 at 1:28 AM
FLIGHTS5628
  • 12 POSTS
Thank you!!!
Nov 18, 2024 at 1:32 AM
