Every light inside and outside of the van pulsates at idle and any speed. I checked the battery and the charge is good and no problems with starting or the engine running. I then replaced the ELD (fuse / relay box under the hood) and the lights still pulse. I have not changed the alternator because the battery keeps a good charge and the engine runs good. If it is the alternator, can the alternator be rebuilt? If it is not the alternator, what could it be? Thank you for your help.
Aug 27, 2010 at 6:23 AM
