2007 Honda Odyssey pin point radiator leak
2007 HONDA ODYSSEY
JREINKER
Engine Cooling problem
2007 Honda Odyssey Two Wheel Drive Automatic 45,000 miles
Have a pin point radiator leak with a small amount of steam coming from one of the lower fins of the front of the radiator. Could this be filled from the exterior with a plug of some sort? The gunks that I could buy haven't worked in the past.
Mar 16, 2010 at 9:42 AM
KHLOW2008
  • 41,814 POSTS
Hi jreinker,
Patching of radiators does not last and sooner or later you would have to replace it, hoping that you do not damage the engine due to overheating.
Apart from replacing the radiator, the next best option is to get it welded.
Mar 19, 2010 at 4:26 AM
