2007 Honda Odyssey Dash lights issues.
22,000 MILES • 6 CYL • FWD • AUTOMATIC
MARK5000
When I turn my lights on my dash lights do not work. My headlights, HI-Beam, turn signal and rear lights operate. However my dash lights do not work correctly. While I turn the dimmer light clockwise (High) my dash does not light up. However if I turn it counter clockwise (low) the lights start to flicker. I had installed an aftermarket remote start/alarm two years ago and recently had issues with my parking lights flashing using the aftermarket alarm. However I fixed it and all is working back to normal but now I am having issues with the dash lights. My alarm is tied into the correct parking light wire which shows (+) when the parking lights are on. Please help... I hope I didn’t mess with the dimmer switch... if so, even if I replace it, how can I make sure this problem doesn’t happen again? Any help would be appreciated.
Mar 9, 2009 at 1:22 PM
JAMES W.
  • 2,394 POSTS
Unless you inadvertantly hooked the power for the alarm to the dimmer circuit, there is very little you could have done to damage it. I have to say, it just plain died. I would think you could go ahead and change the switch without any worry. Hope this helps.
Mar 9, 2009 at 3:50 PM
MARK5000
James,
I rechecked, and it was just a blown fuse.... put a new one in and all is good.
Thanks
Mark
Mar 16, 2009 at 11:09 AM
JAMES W.
  • 2,394 POSTS
Thanks for the response, Mark. Glad you found it. Anything else, you know where to find us.
Mar 16, 2009 at 12:19 PM
