2006 Honda Odyssey Not starting
OLVIERVTEC
Engine Mechanical problem
2006 Honda Odyssey 6 cyl Front Wheel Drive Automatic 69xxxx miles
So basically i drove my van yesterday , perfectly fine. this morning i get in and its not starting but im sure i turend everything off the night before i alway inspect the van before i leave into my house.
the van just cranks l, everything eles as in power is slowing down.
do you know what is wrong ? i put a new battery 1 year ago from HONDA.
Mar 15, 2010 at 10:27 AM
  • 75,988 POSTS
Cranks but no start condition:
Fuel and Spark:
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine at least 3/16 away from ground -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it.
Mar 15, 2010 at 10:59 AM
